clutch questions
Well, first off, the Aisin Warner AX5 is a manual shift transmission and the Aisin Warner AW4 is an automatic. Two completely different transmissions. So, aside from being madefrom the same company, nothing on them is really exchangeable.
Are you confusing the AX5 with the AX4?
CW
i was wondering, is the clutch for the ax4 and the ax5 the same? i ask because i see clutch kits on ebay listed under 2.5 but none of them say whether it's for a 4 or 5spd....
The AX4 amd AX5 are the same with the exception of one gear. So yes the clutch is the same.
