tin moon Posted May 7, 2009 Share Posted May 7, 2009 I have a Motorhome and I tow a car, I would like to tow my MJ instead of the car. Does any one make a front bumper that is designed to hook up to the Blue Ox system. I am satisfied with Blue Ox but would consider another system if the price and quality is right. I have seen photos of a lot of bumpers with a 5K cut in them, It looks like the tow mounts could replace the D rings on these bumpers. I would even go for a stock look by making the foam blocks removable and having the tow blocks under. What are your Ideas. Tin Moon Link to comment Share on other sites More sharing options...
mfpdm Posted May 7, 2009 Share Posted May 7, 2009 Well, as a matter of fact, Blue OX makes a tow bracket for the MJ/XJ. :D Far as using another bumper, I'm sure you could get one that ties into the frame and you could use your system with it. A lot of after market ones out there with D ring mounts. I'm sure you could find or mod an adaptor for the mount. The Blue OX tow bar should be adjustable for witdh. PM sent. :cheers: Link to comment Share on other sites More sharing options...
