reson46 Posted April 30, 2009 Share Posted April 30, 2009 I've been looking into options for replacing the stock steering and came across the JB 4x4 raised steering bracket. The pictures on their site aren't the best so I requested a few larger ones. Looks fairly well built. Do the attachment points look strong enough? See any reason to be afraid of this? Thanks, Willy Link to comment Share on other sites More sharing options...
BLHTAZ Posted April 30, 2009 Share Posted April 30, 2009 I see no reason to be afraid of it. I wish that had been available when I built our YJ, but I used a drop pitman arm, cut off the big end, flipped it over and welded it on to the knuckle to create my own similar set-up. Link to comment Share on other sites More sharing options...
SuperWade2 Posted April 30, 2009 Share Posted April 30, 2009 Are those 3 bolts in the first pic drilled thru the cast knuckle? that seems a little sketchy to me... Link to comment Share on other sites More sharing options...
BLHTAZ Posted April 30, 2009 Share Posted April 30, 2009 Are those 3 bolts in the first pic drilled thru the cast knuckle? that seems a little sketchy to me... Yes...I read about it. You have to drill and tap the holes for the bolts. I would trust that more than the welding that we did on the cast knuckle on our YJ...although ours has held well so far. Grade 8 bolts are going to be stronger than a weld. Link to comment Share on other sites More sharing options...
