j1981jensen Posted April 21, 2009 Share Posted April 21, 2009 1986 4x4 2.4l 4 speed none of my dummy lights work or no lights for gauges work and I have checked all fuses please help. Link to comment Share on other sites More sharing options...
Wildman Posted April 22, 2009 Share Posted April 22, 2009 Check the wire harness where it "Plugs" into the back of the gauge cluster. I tried finding a picture for you.......but :dunno: here's a write up on doing the gauge swap, gives you an idea what to expect :D http://www.lunghd.com/Tech_Articles/Int ... luster.htm You need to take the dash bezel off and pull the cluster out a little (the speed-o cable will hold you back) and try pushing the connector in to the "socket" Oh.....and I hope you meant a '86 2.5L :D And......Welcome to the CC :banana: Link to comment Share on other sites More sharing options...
maddzz1 Posted April 22, 2009 Share Posted April 22, 2009 This write-up shows some good pics: http://www.naxja.org/forum/showthread.php?t=921205 Link to comment Share on other sites More sharing options...
j1981jensen Posted May 6, 2009 Author Share Posted May 6, 2009 thank will check it out Link to comment Share on other sites More sharing options...
