Harmonic balancer
Am I correct in thinking that my harmonic balancer is bad if it is hitting the timing cover on this
It's an 89 with a 4.0
Tried to take picts
You can barely see where the balancer is hitting the cover in this pic.
Or is it possible that it has other problems. Is there a possibility of,I think I read about in another post, thrust bearing ?
problems.
The rubbing hasn't gone all the way through the timing cover (I know it's toast), and there isn't any oil coming from the rear
main seal.
:agree:
It's a fairly common issue.
x2. Same thing happened to me. Sounded just like an exhaust leak. Luckily I spotted it right before tearing into the manifold :banana: Easy to replace and cheap too. Just make sure you use balancer puller and installer. DON'T use a hammer.
