O-ring in front diff housing
when i popped out the driver side front axle seal on my 89 CAD D30 the oring that sits right in front of seal came out with it. there is also an oring on the passenger side of the diff housing. should these be replaced with the seals and exactly what do they do?
sorry about the pic and i don't know why the writing is all fancy i couldnt figure out how to change it
Those help to seal the CAD housing from leaking, and should replaced, esp. if they are coming out when you pull the shafts, as they are apperently shot.
