procomp suspension
hello,
does someone is using the procomp suspension lift kit in from of a MJ? I know that the kit is for a XJ, but in from, it is the same suspension...
if yes, are you using it with the MX6 shock?
how about the coil spring, too stiff or too soft ? :???:
thank !
The kit for an XJ will work fine on the front of you MJ. I don't recall ever running across anyone using a ProComp on an MJ, but I have sold & installed the ProComp coil spring kits on other Jeeps and the customers were happy. ProComp has issues with leaf springs being very stiff, but the coils are fine.
My XJ has a procomp 3.5in front lift that I am very happy with. I think the rear leaves are Rancho full packs. Over all I like it. It has not sagged much at all, it might have settled 1/4in in about 7 years. I did not flog it much, but it did get a few beatings. It was my DD so I had to take it easy.
