spanaway mudder Posted February 15, 2009 Share Posted February 15, 2009 Iam picking up a clean 90MJ for $300.00 that just plain won't start..I re-timed it and had it checked , changed out coil,distributor,cap/rotor,and checked for fuel pressure and spark (not in that order)... its a manual..is there a nuteral safety switch? my friends changed out the CPS also.. 4.0,4wd,5spd.. Link to comment Share on other sites More sharing options...
kar120c Posted February 15, 2009 Share Posted February 15, 2009 I love bookmarks and jeep forums. Below is a CPS test procedure .Could be a bad PDC too I guess. Others might have more input, but it sounds like you've replaced the most common at-fault parts. http://www.cherokeeforum.com/showthread.php?p=67282 Link to comment Share on other sites More sharing options...
mvusse Posted February 15, 2009 Share Posted February 15, 2009 Neutral safety switch would cause it to not crank. You say you have fuel and spark, and checked the timing. That would mean it cranks. Broken timing chain, or worn away sprocket? Be more specific about what exactly it does and does not when you try to start it. How old is the fuel? What do the spark plugs look like? Link to comment Share on other sites More sharing options...
spanaway mudder Posted February 15, 2009 Author Share Posted February 15, 2009 Neutral safety switch would cause it to not crank. You say you have fuel and spark, and checked the timing. That would mean it cranks. Broken timing chain, or worn away sprocket? Be more specific about what exactly it does and does not when you try to start it. How old is the fuel? What do the spark plugs look like? Good point..Iam going to stop by where its at this week to dump some fresh fuel in it, the spark plugs looked decent.. it turns over...thats it... Link to comment Share on other sites More sharing options...
