Spokes Posted February 12, 2009 Share Posted February 12, 2009 i see alot of ppl run the moabs on there MJs and i think it looks rly nice. i found a couple good deal on them and might pick a set up. do they fit the stock bolt pattern? and is the backspacer good or would i need spacers? Link to comment Share on other sites More sharing options...
LEAD_NOT_FOLLOW Posted February 12, 2009 Share Posted February 12, 2009 TJ Moabs will bolt up, JK Moabs will not. They are a 16" rim (thus making the rubber a bit more expensive). Depending on the wide of tire you run, you may need spacers. As long as you keep it under a 12.5" wide tire you should be fine. Link to comment Share on other sites More sharing options...
Spokes Posted February 12, 2009 Author Share Posted February 12, 2009 TJ Moabs will bolt up, JK Moabs will not. They are a 16" rim (thus making the rubber a bit more expensive). Depending on the wide of tire you run, you may need spacers. As long as you keep it under a 12.5" wide tire you should be fine. ok. great. ive got 31x10.5 and they rub when i turn the wheel all the way is why i was wondering. so i guess the backspacing a little differnt. o yeah ive got like 01 chokeree rims. the 5spoke ones Link to comment Share on other sites More sharing options...
johnnyc Posted February 12, 2009 Share Posted February 12, 2009 The TJ Moabs have slightly less backspacing than stock XJ wheels. Link to comment Share on other sites More sharing options...
Spokes Posted February 12, 2009 Author Share Posted February 12, 2009 The TJ Moabs have slightly less backspacing than stock XJ wheels. that might be a problem. or i will just need spacers. Link to comment Share on other sites More sharing options...
redneck23ms Posted February 12, 2009 Share Posted February 12, 2009 less backspacing is better. the less backspacing, the farther the tire is away from the inner fender Link to comment Share on other sites More sharing options...
JohnQ Posted February 13, 2009 Share Posted February 13, 2009 I'm running Rubicon moabs with 245/75/16 MTR's and have zero rubbing issues. Link to comment Share on other sites More sharing options...
Spokes Posted February 13, 2009 Author Share Posted February 13, 2009 ooo so got it backwards than lol sorry. Link to comment Share on other sites More sharing options...
