My 89 MJ Build
man what is with that supper jack? what is that? i don't think ive ever seen one right on jamminz.gif
Brandon
That would be a hi-lift jack ;)
I never go wheeling without one. That thing has saved my butt in a few situations. Can also be used as a winch... one click at a time, lol.
http://www.hi-lift.com/index.html
Got to be careful with them though, they are as dangerous as they are handy!
  • 2 months later...
The front gears are FINALLY on the way! It will sure be nice to get my 4wd back in time for winter! :jump:
Other than that, I am getting ready to go through a "to do list" for the MJ, but unlike my normal off-road modifications, I am actually going the other way, making it more road friendly and reliable. The reason for this is I plan to relocate to Colorado in a few months, and am going to be pulling my camper cross country with it :D
Here is my basic list:
-Change ALL fluids and filters. I will even be changing the PS and brake fluids!
-Replace front gears... FINALLY1 I'll be needing them out there!
-Replace rear shocks and add mounts so I can bolt in a more stock location (currently they are inverted for more travel, but this causes more sway)
-Check ALL joints, bushings, bearings and seals, replace as needed.
-Add extra bracing to rear bumper to make me feel better towing ~4k lbs. I built it strong, but I like overkill!
-Replace stock trans cooler with aftermarket HD unit
-Install trans temp gauge and "autostick" like trans shifter.
-Turn old trans cooler into power steering cooler.
-Wire in trailer brake controller
-Upgrade brake booster/MC to 96 dual diaphragm.
-Change to bucket seats if budget and time allows.
I have already replaced the 35" swampers with a set of non-aggressive 33" ATs. I must say this is the first time I have ever gone down in tire size! The ride is soooo much more road friendly, and it has much more power with the 33s and 4.56s. That should help a lot with the pulling!
I will post updates as I tackle the list, and I'm sure I will find more to add as I go!
Been working on the list! I haven't taken many pics yet, but I'll get some up soon.
DONE-Replace front gears... FINALLY1 I'll be needing them out there!
DONE-Replace rear shocks and add mounts so I can bolt in a more stock location (currently they are inverted for more travel, but this causes more sway)
DONE-Check ALL joints, bushings, bearings and seals, replace as needed.
DONE-switch to 33" AT's for more power and better mileage
Haven't added to the list... but I'm sure it will happen.
