Rear panel clips
how do you remove the panel at the top of this picture without breaking the clips:
There are push pins like the ones that hold the door panels on. So you can use the same tool that is used on doors or just pull on it gently until they pop out. I started in the middle instead of the ends and didnt have any problems.
I already broke one clip. I knew what kind of fastener they used, but I have always used a putty knife on plastic panels to pop those off. On the door panels, I just pry gently with my fingers. Neither worked on that back panel because I did not know where the clips were located. I need to go buy a panel puller tool. :mad:
