Sending unit test....?
My 89 comanche has had the gas tank and sending unit out for about 5 months. I was patching up and closeing all the holes.
Been flat & out with a bad back. Today I tried to sart it.
Nothing engine turns but no fuel.
I check the fuel rod bleeder and nothing came out.
The 2 lines from the tank (sending unit) one is bigger
its the out one and the return is the smaller size,
correct?
Also checked the out line of the fuel filter no gas!
I turned the key on and I don't notice any sound
from the sending unit.
Is there a test for this, if there is how? Are the hoses
correct? Are there any fuses for the sending unit?
I also disconnected and reconnected the map.
