smartazz19 Posted January 5, 2009 Share Posted January 5, 2009 What is this mystery solenoid? Its mounted on the passenger side inner fender of my 86 MJ. It is obviously some kind of solenoid switch, but its a rectangle shape, not like the typical round starter solenoids. I am having charging issues and wanted to replace it since its attached directly to the alternator. It also has about 6-8 more wires coming off it it. What is it actually called, and does anybody have a link to a replacement part? Link to comment Share on other sites More sharing options...
smartazz19 Posted January 5, 2009 Author Share Posted January 5, 2009 Wow, just found it on rock auto. It says its a starter relay. If this relay is bad, this wouldnt cause my jeep not to charge would it? It starts fine.. Link to comment Share on other sites More sharing options...
Ed in North Ga. Posted January 5, 2009 Share Posted January 5, 2009 That looks more like what I call the underhood ignition switch/dristribrution box- behind the battery/in front of the relays- if old enough, ya- but most charging issues are old batteries, old alternators, or the evil thin wire between that needs upgrading. remember- the dash guage is wrong- it lies. Link to comment Share on other sites More sharing options...
BLHTAZ Posted January 5, 2009 Share Posted January 5, 2009 It is the starter relay, but I am not an electrical wiz by any stretch of the imagination so I don't know if it would have anything to do with charging. Link to comment Share on other sites More sharing options...
aemsee Posted January 5, 2009 Share Posted January 5, 2009 I went and looked at my truck. The alt charge wire goes to the stud on this relay just to use it as a junction point, but there is a fusible link on there. Did you check the link? Link to comment Share on other sites More sharing options...
smartazz19 Posted January 6, 2009 Author Share Posted January 6, 2009 I went and looked at my truck. The alt charge wire goes to the stud on this relay just to use it as a junction point, but there is a fusible link on there. Did you check the link? Smart man. It was indeed the fusible link. I actually fixed it this afternoon before checking on here. It did not burn, it was just very badly corroded and i could feel the wire was disconnect inside the plastic. Based on that I decided that it was time to replace all my cables. I replaced both my battery cables and the alternator wires. I think it was $20 well spent. I also added a ground wire from the battery to the sheetmetal. Now I'm charging at 14 volts and have brighter headlights That looks more like what I call the underhood ignition switch/dristribrution box- behind the battery/in front of the relays- if old enough, ya- but most charging issues are old batteries, old alternators, or the evil thin wire between that needs upgrading. remember- the dash guage is wrong- it lies. I installed a cheapo sunpro volt meter from autozone a few weeks ago when I thought something was wrong, sure enough it was the same crappy voltage as it was reading on the dash.. :ack: It is the starter relay, but I am not an electrical wiz by any stretch of the imagination so I don't know if it would have anything to do with charging. It doesnt have anything to do with charging, i guess jeep decided to use this starter relay as a junction block. 2 wires from battery on my 86: Battery---> main stud on starter relay ---> alternator (i used 10ga wire with a new fusible link) Battery ---> starter (4ga big cable) Link to comment Share on other sites More sharing options...
