2wd to 4wd conversion
hey everyone. had a question. i got a 87 mj and in the process of looking for a 4x4 donor or use through winter then swap in spring/summer. what year up to can i use the running gear from. i would perfer to keep the truck with the aw4 transmission. thanks. also. can the full time transfer case be bolted up to an aw4?
Find a 87 through 90 Cherokee 4.0/auto with the 242 transfer case. I believe up to and including 90 would still have the mechanic speedo, the transfer case bolts to a AW4, and everything you need is there with the exception of the rear drive shaft. For that take your 2wd shaft to a shop to have it shortened. Assuming your MJ is 4.0/auto, the front axle ratio should match your current rear axle.
