Turbo Questions on a 4 Cyl.
I want to turbo mine, I was gonna remote mount it under the bed, just no time to worry about it at the moment. t3/t4 hybrid should do well, you will need a timing retard setup(msd or the like) and a vacuum variable fuel pressure adjustment to manage fuel if you do not go to a new computer setup, I think holly makes one that is pretty good.
I want to megasquirt mine first, then add the boost so I can control timing and fuel easier.
