will these gears fit my comanche's dana 30?
Based om this...
DANA 30 RING & PINION GEARS
SPECIFY RATIO REQUIRED:
4.11, 4.56, 4.88 CJ Style Standard cut gears
4.11R, 4.56R, 4.88R Reverse Cut / High Pinion YJ Style Gears
4.11TJ, 4.56TJ, 4.88TJ Short Pinion Standard cut TJ Style Gears
3.73 carrier required if current gears are 3.07-3.54. May be purchased in our Ebay Store
I would say this guy has BOTH, as the TJ and XJ/YJ gears are different. Just specify yours as a XJ/MJ with a factory HI-Pinion D30 and you will be fine.
ALSO, you will need a carrier that will support the taller gears as there are two dfferent ones based on what your axle has now.
CW
