SlickRick421 Posted June 27, 2006 Posted June 27, 2006 I have searched my entire motor for this oil leak I am having and havent found much I think it is my Drain Bolt but every where I park there will be a spot Need help if anyone else has had this problem I am running a 2.5L 90 Manche 147K
87manche Posted June 27, 2006 Posted June 27, 2006 have you degreased the engine before looking? My guess is valve cover, it's the most common, and will leak down the back of the motor, making it hard to find.
SlickRick421 Posted June 27, 2006 Author Posted June 27, 2006 I have degreased still nothing I think i need to replace the gasket around the drain plug I shoud be fine after that i looked at it at lunch
mjeff87 Posted June 27, 2006 Posted June 27, 2006 remember, oil doesn't leak upwards. Find the highest spot that you can see oil and search from there. My 2.5 seeps from the rear of the valve cover (among other places :cry: ) and eventually ends up down the side of the block to the pan. Good luck! Jeff
