mjtjnj Posted October 24, 2008 Share Posted October 24, 2008 Hi, As some may know I'm having problems with the TPS, which I plan on taking care of this weekend. My friend actually has access to an MT-2500 scan tool. I'm also running rich, and failing inspection, which I never did before the rebuild, and this is with all NEW SENSORS (except the TPS). I even replaced the 02 sensor under warantee, to make sure -- I'm getting very high hydrocarbon and CO% readings. Anyway, the MT2500 won't tell me everything, I'm guessing, what help will it be in this situation? Also, there's manuals out there on the internet for testing sensors on a 4.0 RENIX system, do the same numbers apply for the 87-90 2.5 as the 87-90 4.0? thanks! Tom Link to comment Share on other sites More sharing options...
BLHTAZ Posted October 24, 2008 Share Posted October 24, 2008 I have the full '88 FSM that shows/covers all configurations. If you would like a copy and your email can receive a file that is slightly larger than 17mb, PM me your email address and I will send it to you in a .ZIP file. The expanded file is about 27mb and includes all the different sections of the FSM in individual .PDF files. Link to comment Share on other sites More sharing options...
