shawn Posted October 9, 2008 Share Posted October 9, 2008 things such as interior lights, dash lights and heater fan just don't come on. well, heater fan did 4 a while. also radio has never come on. i changed some fuses and they were corroded to say the least. - is it a fairly simple thing to change the fuse box - i have no experience with that and was wondering if it is a simple procedure. Link to comment Share on other sites More sharing options...
jbhill Posted October 9, 2008 Share Posted October 9, 2008 from what ive gathered on here, check the clutch master cyl. isnt leakin on the fuse box since its right below it. Link to comment Share on other sites More sharing options...
Kenosha Warrior Posted October 9, 2008 Share Posted October 9, 2008 go grab an aerosol can of Contact Cleaner, yank your fuses and let loose into the block. Maybe pull it off the firewall so you can see if there is any corrosion from master-cyl leakage. Link to comment Share on other sites More sharing options...
shawn Posted October 10, 2008 Author Share Posted October 10, 2008 ty - will give that a try in the morn. i was wondering if the block might just unplug and be easily replacable. Link to comment Share on other sites More sharing options...
