i think my clutch is dying
have you check the fluid level in the reservoir that would be the firts think i would check first if it is dry you may have a leak. check for signs of a leak either by the tranny B/H o some where along the line. Then determine how many miles since the last replacement clutch. If not driven hard the should last a good long while i had one last 125k with the puke joe. then i have replace it with an ax-15. which is better since i have stroked my engine.
