mainemj Posted June 10, 2006 Share Posted June 10, 2006 have any of you guys used the tnt ylink kit if so please give me feed back on the install and overall proformance thanks in advance Link to comment Share on other sites More sharing options...
whowey Posted June 10, 2006 Share Posted June 10, 2006 I helped a friend put his on. WOW!!!!! That was a ton of work. There are a ton of brackets to drill holes for and align. Make sure you have any T-case stuff done before you put it on. That bellypan/mount assembly they use makes any work a pain. Make sure you read all the directions FIRST. There are a couple of places they aren't clear enough, and if you don't read the next steps you can really botch things. Link to comment Share on other sites More sharing options...
