mjtjnj Posted August 18, 2008 Share Posted August 18, 2008 So I wired up my PermaCool fan to this Imperial (by Hayden) fan control. Has a wire to battery, ground, fan(+) - with fan (-) to ground, backup power wire (for ignition off fan operation), and a wire to a/c. The way to test this before finding out it doesn't work and cooking your motor is to turn on the a/c and see if it kicks on the fan. I didn't splice it into the a/c (+) wire yet, but did give it 12 volts, and the fan didn't come on. Tested the grounds and they are good. I hooked the backup power wire to the fusebox with a female butt connector to one of the "Batt" spade terminals. Should the backup power go somewhere else? Does the a/c(+) give 12 volts? I always like to assume the part works out of the box, but I suppose that could be the problem too. Anyone?? :mad: Link to comment Share on other sites More sharing options...
