Shane Posted July 21, 2008 Share Posted July 21, 2008 I have had plenty questions about mods for my 89 MJ. Thanks alot to those who gave me advice. I love these trucks and have done a decent amount of research about them, however, it appears that I have not done nearly enough. On the driver side under the speedometer there is a switch that appears to have a trans on it and one way says power and the other says comfort. What is this about and which one should I have it on to drive daily? Thanks again Link to comment Share on other sites More sharing options...
offroader461 Posted July 21, 2008 Share Posted July 21, 2008 its the power/comfort switch....the later models don't have them b/c they are "hardwired" to power...you can run either.. Comfort setting is a lower/softer shift point and you get a slightly better MPG Power setting will rev longer and shift a tad harder My XJ has this switch and mostly i just leave it in the comfort setting just to get the slight MPG increase is all Link to comment Share on other sites More sharing options...
