Another question on 'decontstruction'
Well, I've hit another snag on the jeep from hell...
Can anyone advise me on how the engine harness comes apart from the interior fuze panel? I have removed the two screws inside but cannot get the wiring halfs to part. I have removed the two plastic pieces on the harness inside the engine compartment (thinking they were some kind of retainer) without success.
Image Not Found
Image Not Found
Image Not Found
Image Not Found
As always, your assistance is appreciated! :cheers:
I've pulled apart a couple of '91s and '92s; not sure if this applies to other years. On the engine side between the two halves of the engine harness there is a small bolt. I'm almost positive the bolt needed a 1/4" socket. I found removing the two torx bits on the interior fuse box helpful. It allowed me to move that whole connector up and out so i could get at the bolt with just a ratchet and extension.
