Fsj Super Swamper Posted July 1, 2008 Share Posted July 1, 2008 What would the axle spline count be on a 1986 MJ Dana 30 CAD, with 4.11 gears??? Its all stock, & never been swapped out. Thanks for your time................... ;) Link to comment Share on other sites More sharing options...
LEAD_NOT_FOLLOW Posted July 1, 2008 Share Posted July 1, 2008 Dana 30 high pinion - reverse cut - 27 spline, 1.16" diameter shafts, 7.13" ring gear - used 86-92 (all axles are vacuum disconnect, and have 5-260x u-joints) Link to comment Share on other sites More sharing options...
Fsj Super Swamper Posted July 1, 2008 Author Share Posted July 1, 2008 Dana 30 high pinion - reverse cut - 27 spline, 1.16" diameter shafts, 7.13" ring gear - used 86-92 (all axles are vacuum disconnect, and have 5-260x u-joints) Thanks that is just what I needed too know................ Link to comment Share on other sites More sharing options...
