JohnQ Posted May 24, 2006 Share Posted May 24, 2006 Will a front axel from a jeep TJ bolt on to a comanche with no modifications? Link to comment Share on other sites More sharing options...
87manche Posted May 24, 2006 Share Posted May 24, 2006 I think so, I know a fella with a newer TJ that took a HP D30 out of a 98 XJ and it bolted right up. TJ's usually come with different gear ratios though, so you're gonna want to check that. Link to comment Share on other sites More sharing options...
Mudzilla Posted May 25, 2006 Share Posted May 25, 2006 It is a direct bolt in swap. The air pump for the locker runs about $60 each, or $90 for a pair from a Jeep dealership (if I remember right). Link to comment Share on other sites More sharing options...
pingpong Posted May 25, 2006 Share Posted May 25, 2006 TJ axles are lp axles, which might cause D/S vibes with larger lifts. Link to comment Share on other sites More sharing options...
JohnQ Posted May 25, 2006 Author Share Posted May 25, 2006 TJ axles are lp axles, which might cause D/S vibes with larger lifts. What is a "lp" axle? Link to comment Share on other sites More sharing options...
pingpong Posted May 25, 2006 Share Posted May 25, 2006 LOw pinion. It means the pinion is below the centerline of the axle. Link to comment Share on other sites More sharing options...
