elvismerc
Everything posted by elvismerc
  1. If you put a radiator and electric fan in the bed. You will have more then enuff cooling.
  2. Thanks to everone who helped me with my comanche not starting problem. I'm a @$$ and lost the bolt to the cps and just used another i had laying around. Put the right bolt in like someone had said and she fired right up THANK U
  3. yes i have hooked up the nutral safty switch i looked to make sure like 50 times. is there anything special i need to do to put in the cps? thanks
  4. i have driven the truck for more then a year with no problems. was running great then the clutch slave went. put a new clutch and slave in and now it won't start . me and two friends have looked all over the motor and can not tell were the red wire off the blower motor goes.
  5. no, i was not getting spark with the old one. thats why i think it's the red wire off the blower motor. do you know what that wire might go to. thanks
  6. I just changed my clutch in my '88 Comanche 4.0. It will not start now. I replaced my crank shaft position sensor and I still have no spark coming from my coil. I found a red wire coming off of the blower motor that has power going to it with the key off. What does that red wire go to? It does not control the blower motor. Thanks in advance for any help you may give me.
