twojeeps
Everything posted by twojeeps
What size lift is this>> with pics
twojeeps replied to twojeeps's topic in MJ Tech: Modification and Repairs
won't be using those extenders fo sure!!! -
34.5" on the XJ 30.5" on my MJ -
Wonder how I could measure?? Just don't want to order the wrong springs for the rear. Do you think I could swap the front over to the MJ, then measure the rear to see how much I need it to come up?? Thanks -
correct, 31's -
This is my donor XJ.... trying to get an idea of lift size that is on the donor, either by looking at the pics.... or some direction on how to measure. Need to know what size springs to buy for MJ rear because i am going to swap the lift to the MJ. Thers is a "Rough Country" sticker on the driver visor that talks about driving a vehicle with a lift. THANKS!!! crazy looking shock extender
wire harness swap question
i am pulling all engine harness and pulling all dash harness from 92 XJ and swapping to 88 MJ. did not really want to pull wires from floorboards back, so if i can't plug XJ harness to MJ rear (fuel pump, lights, etc) i will just splice since it should be just a few wires. -
I got the dash apart on the 92 XJ, so I can swap the harness to my 88 MJ. Am I going to have to splice some wires for the fuel pump, rear lights, etc, or will the XJ dash harness just plug into the MJ rear wiring?? Hope this makes sense..... Thanks!!
NO VACUUM ACCUATOR on front axle
thanks! thought i was missing something -
Sorry for the stupid question..... but there is no vacuum accuator on the 92 XJ that I just picked up..... Would you give me more info on this axle?? Thanks
FINALLY!!!...a couple of pics of the family workhorse.
twojeeps replied to Imperial21's topic in The Pub
nice mj...... what lift are you running? -
I believe so.... I plan to take all that stuff from XJ to MJ. There are a few driveshaft shops I have seen close by, that did slip my mind. Its a longbed. Thanks for all the responses!
i know there is a bunch already written on this topic, but any input is appreciated!! I have an 88 MJ 2wd and I just bought a 92 XJ that I will be using as the donor. Pretty straight forward in my mind, however I have never done more wrenching than insalling a lift on my CJ. here's the plan.... - Pull everything from under the hood on the MJ - Pull everyting from underhood on the XJ and put all in the MJ - Pull all dash, wiring and interior from MJ - Install all dash wiring and dash from XJ to MJ - Install front end from XJ to MJ I plan to change water pump, thermostat, belt and radiator while engine is out. I will be borrowing an engine hoist, but will be doing most of the work using hand tools. Am I missing anything?? Thanks!
I am in Tampa, near the Hard Rock! Drahcir495- where are you??
I would love to see some! THANKS
Not really sure what to do.... was hoping to get 4.5 for less than 1K, kinda like the looks of the motion offroad set better,,,,, hmmmm
sorry for the stupid question, but i need some suggestions. going to be a mild wheeler and truck for the weekend home depot runs. i know this is all over this site, but just having trouble deciding!
Can I get a good 4.5" lift for less than a grand?
1990 Jeep Comanche Pioneer 2WD 4.0L Automatic
twojeeps replied to GGosa's topic in Member Projects: Your Comanches
where is holly hill? -
ITS FIXED!!!!!!!!!!!!! it was the fusable link!!!!! THANKS
e-brake is next to clutch. it did rub the wire a little, but did not pinch. fuses are good. still nothing but the buzzer when i turn the key. lights work. fuses anywhere else?? could it be the relays by the battery or something else in that area??? i see no burnt wires. HELP and THANKS!!!!!!!!!!!!
just got in the MJ, started it right up.... pulled the e-brake and it shut off..... turn the key..... NOTHING..... open the hood and smell an electrical burning smell over by the relay/ battery area....... WHAT HAPPENED?????? '88 MJ 4.0
i think i finally got it! started it, let it run a while, let it sit, filled the tank up more, did this a few times, let it run a while, drove it a few miles and it didn't boil. got my fingers crossed thanks for the help!
hoses are fine...... guess water pump is next, didn't really want to tackle that. i think its burped pretty good. its still boiling over should i replace coolant tank before water pump?? bought a new one today at dealer, was hoping i could take it back THANKS
how do i fix that
