My fuse box is shot. I found a upull yard that had a 86 4 cylinder 4x4 auto MJ that I pulled the dash harness out of. Wasn't bad at all only took about 20 minutes (without tearing anything up).
The plan is to just swap it out directly with my 87 4.0 4x4 5spd. I've done some searching found all the posts about using xj harness, cutting and splicing, replacing terminal connectors, but just hoping you guys can confirm that the direct swap will work, and if it will be plug and play, or if there are any known issues I'll have to address.
Thanks in advance for your time and replies...
