Got my first MJ. My little brother has been into XJ's for a while so I have learned alot from him, and decided to build a jeep because of that.
Had some wiring issues, in which the fuse box was the culprit. The radio was ripped out along with the speakers, the interior lights behind the seats don't work. The turn signal was broken, so I replaced it with a used one that came with the truck (which had a different problem). And probably last the door hinge was "fixed" at one point, but it was not done right so the door is not aligned right.
The a/c lines have been cut, the truck is a 2wd longbed with the peugeot tranny.
My brother and I are planning on doing the 4wd conversion this summer once I restore the truck somewhat.
I have half my drivers floor cut out (in the process of replacing it). Whats the best way to remove the top part of the frame rails?
I'm using replacement floor panels. The rust goes almost to the fuse box so they won't cover it all the way.
