lthixson
lthixson's Achievements
Can Spell Comanche (2/11)
Started taking the canvas off of the Wildernest, all of the screws that hold the base on had to be removed with an impact driver. I'm going back with stainless steel fasteners after the tent is cleaned. Then I'll use tent tape to patch the rips, seam sealer on the seams and a couple coats of water-repellant. Pics to follow...
Continuing with the "expedition" Comanche. After buying the Wildernest (which i still haven't detailed) I began looking for a parts truck. I ended up finding a long bed in Dallas and I was able to get the fuel system and some other odds and ends off of it. I thought that with a little fabrication I could make the 22 gal tank fit in my short bed...uh, nope! So I ended up using the LWB fuel pump/sending unit, filler neck, straps and gauge but had to buy a new 18 gal tank. The installation was straight forward because it went in the stock location. I capped off the return line and Teed the supply line into the Cherokee vapor line. I installed a momentary switch, adapted the fuel gauge and installed it in my console just in front of the 4WD shifter. The gauge reads about 1/8th of a tank too much, but functions correctly other than that. The pump transfers between 1-2 gallons/minute from the stock Comanche tank into the Cherokee tank. The Cherokee tank supplies the engine. I now have 38 gallons of gas onboard, essentially doubling my range.
I bought a 1988 - 23 gal tank from a JY. I have a '87 SWB. Can I switch everything (pump, sending unit, vents) to a new 18 gal tank?
Okay, let me try this again. My MJ has two gas tanks. An xj tank where the spare was - this supplies fuel to the engine. AND the original MJ tank - It's not being used right now. I want to hook the MJ tank up so that it fills into the neck of the XJ tank (just below the gas cap) using a quick connect. When the xj tank gets low I can switch the MJ fuel pump on to fill the xj tank. The quick connect will stay connected unless I want to fill a portable container. Then I can disconnect it and turn on the MJ fuel pump with a switch, filling the portable container. I'll have two switches for the MJ fuel pump. One in the cab and one by the quick connect. Either will activate the MJ fuel pump independantly of the other. My question is: How many gallons per minute does the MJ fuel pump put out?
I've got an xj fuel tank, located where the spare was, on my 97+ conversion. The filler neck is in the bed, mounted to the side wall. I want to have the original gas tank fill into the xj tank when I flip a switch. Will the stock fuel pump do this in a reasonable amount of time or should I buy a high volume transfer pump? Rather than mess with the xj tank could I have the mj pump fill into the filler hose of the xj tank. I'd like to have some sort of quick connect so that I could fill portable containers from the MJ tank. What do you think?
Couple of pics from our day trip to the Capitan Mountains, north of Roswell, NM. Just a day trip, so we haven't gotten to use the tent yet.
b16gsr & Backdraft. - The top of the camper opens like a clamshell. The top is supported by poles and that becomes the platform where you sleep. It's rated for 500 lbs. When the top is open, the area directly above the pick-up bed is open with about 7' of clearance. There is a zippered canvas "ceiling" that keeps the tent from falling into pick-up bed when everything is closed.
RockMJ- The Wildernest campers are quite rare, especially the 6' models. I used searchtempest.com to search all of the Craigslist ads with 500 miles of me daily. I was willing to travel that far for one if I had to.
Backdraft - No. I was literally there for 5 minutes. Just long enough to get the pics.
The tent went up in about two minutes. Two big rips, half a dozen small holes, missing a couple of support poles and filthy! Looks like a good project.
I found a 6' Wildernest camper in Austin. Called the owner, negotiated a price and headed down. My route took me close to Comanche, Texas. It was only a 30 minute detour and I couldn't resist the photo op! Any way....14 hours, 800 miles and $275 later; I am the proud owner of a more than slightly used Wildernest Camper! It's a little rougher than I would've liked but it came with Thule crossbars and Yakima bike racks, so I guess its a wash. I'll try to get a picture of it set up tomorrow. Then it'll come off the truck for refurbishing. This was the first long distance trip with the MJ and it did great. No mechanical problems and it averaged 17.5 mpg! :cheers:
Installed the limo lights, referenced in other CC posts, in the B-pillars. They, and the cargo light, are activated by a switch on the dash, not when the doors open. Installed neoprene seat covers. Not the best fit, but they are waterproof and similar to Okole for 1/8th of the price.
I've got a line on a 6' Wildernest Camper. The topper looks to be in good shape but the tent has some small holes. dry rot and general mildew. I've never repaired a tent before. Is it worth cleaning/repairing and what is the best way to do it, or should I have a new tent made? If new is the way to go, where is the best place to get it done and what kind of price am I looking at?
