shortround
shortround's Achievements
  1. I think i have solved it but thanks for the advice. I took it in to a friend to get a alignment done and said it was either the shock or the steering dampner. So i replaced the steering dampner and sloved it. i will add a photo if someone can help me figure out how to add a photo on this thing.
  2. I checked for extra play in the passanger tire by trying to move it the tire when i had it on jack stands but nothing seemed to have a lot of play and the panard bar is tight i know that. There is no front drive shaft right now i don't havethe money to pick it up from the shop that shortened it for me.
  3. Yes it has a new dash with the electronic speedand i replace the sending unit on the transfer case.
  4. yeah i know but i drove my last jeep for a year with out it and did fine. I hardly ever take it on the highway where the sway bar come into acount.
  5. My plans for the jeep is to use as a daily drive and weekend mudder. The front supension works great other then the bounce i get.
  6. well the sway bar I'm going to leave disconnected the brake line i built new mounts for them and the control arms look fine the coil is still strait and compresses fine. but i don't think any of this thing would cause the front right wheel to bounce.
  7. i just replace the coils and shocks and a new drop pittman arm. i drive great for week then its started to vibrate.
  8. in my 86 comanche with a new wiring harness from a 91 cherrokee and a new i6 drivetrain i can't get the speedo to work. I don't know where to start looking. Any suggestion?
  9. I have a 86 jeep comanche that started as a 4cyl and i changed the motor and drivetrian to a i6 lifted it 4.5 in. Now when i hit a bump above 35 the right front wheel will bounce and vibrate the hole truck. I can't find anything wrong. i checked for play in the ball joints and the wheel bearing. Nothing. It will happen then go away then come back. i don't know where to look. Any suggestions?
  10. The heat in my 86 jeep comanche won't work i can feel that some heat will come out of the vents but the fan won't blow. Do you have any idea were to start looking for my problem?
  11. i have a running 2.5 liter from a 86 comanche. it is still in the truck and i don't think i will have time to remove it till dec but if your willing to wait that long i will sell it to you for 150.
