LakeOzarkMJ
Everything posted by LakeOzarkMJ
  1. Thanks for the advice and inspiration everyone. I think I'm going to try one of the Dakota 3rd brake & cargo lights. Looks OEM. I'll see if I can splice the leads for the brake and the running light, then run the cargo lights to the dash switch. Wish me luck haha
  2. This is great info. Mine is a 92 without the cargo light. So does the third light only activate when you depress the brake? As in it won't operate as a running light when you turn them on/increase in intensity when you depress the brake?
  3. Longtime lurker, first time poster. I've seen a few posts on installing a third brake light and separate ones on a cargo lamp, but I hadn't really seen one on doing a combination that answered my questions. I saw one that was for a topper, but not the cargo lamp area. Ultimately, I want the cargo lamp to hook up to a (to be installed) OEM cargo lamp switch in the dash, but then use an aftermarket third brake light/cargo lamp combo over the bed. I've seen a few OEM ones from an old Ford Ranger, but I think I'll stick with something newer for simplicity's sake. A couple open ended concerns and various questions: I've seen it mentioned I may need a third brake light logic module. Is this just if I'm tapping into the taillights? I'm not sure what's going to be more difficult: tapping into the brake pedal switch or the tail lights. I imagine running something in the cabin would be easier than going all the way to the rear of the truck. I saw there were issues with the third brake light flashing when you tap the brake. How do I make sure it's running whenever the lights are on? Should I use the module and tap into the brake pedal and the front headlights so it knows when to turn on? Then separately wire and ground the cargo lamp? This truck has been a learning hobby and I'm very new, so feel free to correct me where I'm not making sense or even asking the wrong questions. I may just give up and do a factory cargo lamp only, but I think having some extra safety from rear ends in a non-airbag vehicle + cell phone distracted drivers may be helpful. I attached a couple photos of the parts I'm considering. TIA!
  4. 1J7FJ26S8NL192914 purchased from 01yellowxj on November 24, 2024 in Middle Tennessee. Now in Lake Ozark, MO.
