Weston Brown
Weston Brown's Achievements
  1. You will need to bleed the whole system using a traditional method of your choosing and then crack the front brake bleeders to create a low pressure indicator for the load sensing valve to reset. Tighten the front bleeders. Bleed them all again and you should be good. It worked on my ‘91 Comanche.
