SequioaMancheBoogers
SequioaMancheBoogers's Achievements
Reverse Engineering a TCU.
SequioaMancheBoogers replied to SequioaMancheBoogers's topic in MJ Tech: Modification and Repairs
New Computer, and one that's relatively affordable. -
Sike, just found NickInTimesDesign reverse engineering work. -
I'm probably going to at least ATTEMPT to try and develop a homebrew TCU. But first, I'd like to have what the common issue with the TCU's, and what makes them $#!& the bed. Is it a hardware issue? Is it a software issue? Has anybody else attempted this? I am fairly new to this forum, and I'm sure a lot of you fellas have already looked at the threads way more than I have, but again, I'd like to troubleshoot the problem so I can decide how far I want to take this. If it works out, I'd like to post the entire process and open-source it so people don't get scalped on renix TCU's. A build list, an assembly guide, and a cost amount, assuming that this would come to fruition. Any help would be appreciated. Thanks in advance.
Comanche Stuck in 3rd
I have a multimeter, 3D printer and a 3 speed manual jeep, I'll see if I can figure that out. Thank you!- 24 replies
- transmision
- stuck
(and 2 more)
Tagged with:
Trick question, it is NOT the same thing. I just forced it in there, now when I put it into D it'll start in 1st, but won't automatically shift. So I definitely need a another TCU.- 24 replies
- transmision
- stuck
(and 2 more)
Tagged with:
Yeah, it's teal. It does the same thing though, no? Would I be able to swap the connectors? Same voltage, same company.- 24 replies
- transmision
- stuck
(and 2 more)
Tagged with:
Also, I looked/cleaned/ all the connectors, no change. I got this new TCU relatively cheap, not really crying about it.- 24 replies
- transmision
- stuck
(and 2 more)
Tagged with:
So I have a TCU from a 90's jeep that I just got off market place. However, MY tcu said 86, although my jeep is a 87 (might have been marketed as such, and assembled in 86) and the TCU I purchased today, says 91. I've tried the connector for it, same pins, but there's different grooves. Will this work if I swap connectors? They look the same, they run the same voltage, I just don't want to install it and then @#$% something else up.- 24 replies
- transmision
- stuck
(and 2 more)
Tagged with:
I will give her a go, thank you man!- 24 replies
- transmision
- stuck
(and 2 more)
Tagged with:
Yeah I'm actively looking on here for a solid TCU troubleshooting guide. I appreciate the both of you for y'alls help! I'll look at both in the morning! While I was under there, I noticed one of the connections was cracked, not sure if it's holding continuity or not, but it doesn't look right so I'll end up replacing it anyway. Thanks again!- 24 replies
- transmision
- stuck
(and 2 more)
Tagged with:
Appreciate your suggestion! Can you point me in the direction of like a troubleshooting guide? I've looked at my TCU inside and out, and so far I don't see any burnt out capacitors/terminals upon visual inspection. Are there any good wiring diagrams? I've tried to look them up before but all I see are Ebay ads for people selling their's.- 24 replies
- transmision
- stuck
(and 2 more)
Tagged with:
Okay, looked under there, found the selector switch, how do I go about troubleshooting this?- 24 replies
- transmision
- stuck
(and 2 more)
Tagged with:
Checked that one as well!- 24 replies
- transmision
- stuck
(and 2 more)
Tagged with:
Thank you pizzaman09, do you mind elaborating which side? I apologize if it seems like I need my hand held, truth of the matter is, I do.- 24 replies
- transmision
- stuck
(and 2 more)
Tagged with:
That was the first thing I checked!- 24 replies
- transmision
- stuck
(and 2 more)
Tagged with:
