This is posted on the JeepForum as well, I will probably only keep one of the posts completely up to date and cross post as necessary.
I bought my place in 2017 and requested the owners leave this 89 Pioneer on the property. It was running, barely when I closed on the property and I drove it around a bit. The brakes were almost non-existent, the windows are in shambles, and the ignition switch is jacked. So it got parked.
The bad: Rear window, ignition switch, drivers seat, passenger fixed window, wheels and tires, exhaust, minor body dings and dents, some light surface rust
The good: 4.0 Engine ran fine, AW4 tranny is good, 4wd works perfect, it would still roll with inflated tires so nothing is seized ,
I am unsure at the moment what I am going to do with it. First, I am getting the lost title replaced, luckily the neighbors are the kids and POA for the people we bought it from, so they are willing and helpful on that front. Second, I am getting some wheels/tires so I can at least roll the thing around. My tractor wasn't thrilled having to drag this outta the field . Third, I want to get it running and driving again, so, clean up the engine and fix up the brakes.
My options after that are.
#1
Make it nice enough for a ranch truck. Wheels/tires, Windows, Brakes, general maintenance.
#2
Somewhat restore it, but keep it mostly stock. All of #1, plus interior fixes, maybe a paint job, bed liner, inspection, registration, insurance.
#3
A multi year full 97+ XJ swap, 6.0 litre LS swap, etc
These pics should give you a good idea about the rust situation. Anyone ever run brake pudding? Wonder if that viscosity is an issue.
I hooked up a small battery and jump pack to crank it over, cranks fine. Has a small oil leak from drain plug, oil didn't look terrible. No water, so that's a plus.
Nice Mt. Dew heat shielding 😆
Oh yea, one thing I forgot, bad news, Dana 35 rear end.
Engine Crank Vid
Got the wiring fixed and learned that 7 volts with the key on is normal for priming the pump, and when it's running it gets 12v. Good news.
Bad news, I found the rust 🫣.
Tank and fuel pump/sending unit ordered. Should be here this week and I think she'll be running.
Looking for some factory Jeep alloys that will bolt on/fit without any modification. I like some of the factory 16 inch wheels but am not finding much in my local used market.
