Johnboy
Everything posted by Johnboy
  1. The Peuget BA 10/5 transmission had a bolt for the transfer case shifter linkage. The AX15 does not have a place to bolt transfer case linkage. Does anyone have a solution?
  2. The Dana 35 in my 1988 long bed gave up so I replaced it with a ford explorer 8.8 limited slip. Fit up went well, disc breaks work great but I’m having a hard time finding E break cables. Anybody know where I can get them?
  3. My current Dana 30 has 3.07 ratio high pinion reverse cut. I had no idea that not all Dana 30s are configured the same. I was able to find 3.54 ring and pinion through East Coast Gear supply. Derf was right, they are a great company to work with. Doing a little research with a 3.55 rear and 3.54 front there should be no problem as the difference is about 3%. Thank you all for the help.
  4. Thanks Derf. I don’t plan on doing this one myself. I’m getting the parts and having a friend who is a mechanic and has done a lot of diff work do the ring and pinion. I’ll take a look at east Coast gears.
  5. Thank you Gonzo, I’m looking now
  6. My Dana rear 35 gave up on my 1988 MJ manual. So I’m doing an Explorer 8.8 swap with 3.55 ratio. Does anybody know where I can order 3.55 ring and pinion for my front Dana 30
