Thanks for the info. You're right about the firewall. I have the engine and trans bolted in and the trans clears fine. I will have to modify the firewall a little right behind the exhaust manifold flange. I should only have to beat a small spot in about an inch or so. also the trans cross member will have to move back some and a driveshaft will have to be shortened
As for the wiring harness I am using the whole 94 cherokee harness dash and under hood as well as the steering column and complete dash with cluster, heater,A/C box. I will have to adapt the harness for the rear lights and fuel pump. This is the easy part for me since I work on automotive electrical. I will have to cut a couple of new holes through the firewall for the trans wiring harness and the shifter cable. I will be using the 94 radiator supports bottom and top and hood. I'm sure i'm in for many more obstacles. :mad:
