My first ever forum post, advice is more than appreciated! Gotta provide a tiny bit of history. This Comanche had been sitting about 12 years till I got around to it due to needing new floor boards and running extremely rich. I cleaned the ground on the firewall, replaced MAF and 02 sensors, oil was flushed then changed, flushed all other fluids, and it ran like a dream for a couple weeks till I did some more work on it. I replaced cap and rotor, ignition control module, coil, plugs, wires, some broken vacuum lines, power steering and alternator/generator belts, newish (2 year old and unused) recharged battery, PCV valve, coolant bypass hose and finally the fitting on intake manifold. When I went to flush and bleed the coolant after all that, it started up and idled absolutely perfect like nothing happened. After about 5 minutes it shut off but it started right back up. Finished bleeding the coolant and went to back it out of my shop and it died as soon as it was out the door and would start but die immediately after. I ordered and installed a new fuel pump and sending unit from “justgastanks.com”. Once I did that itll run for a couple minutes and then die and won’t idle again unless I leave it be for a while but will start and instantly die like before. I then replaced the CPS, fuel pump relay and 02 sensor heater relay with “URO parts” brand from autozone and I cleaned the multi plugs associated with the relays. Now I can reliably start it by priming the fuel pump three times using the ignition, and it’ll start up for a couple minutes then dies but usually starts up after priming the fuel pump a couple times again. Currently cleaning the ground behind drivers tail lamp and removing the trailer harness that some one botched (what are you towing with an anaemic 2.5 anyway). TLDR MJ randomly dies after lots of work.
