Silverfox
Silverfox's Achievements
  1. I realize that this might be a little late but I thought I would add something for anyone who might come across this post. If you cut your relay open you will find a thin band clamp that holds the relay pins. When the relay is energized it will draw the ins to the closed position. I was having the same problem with the drl and the 5.5 volts that kept closing the circuit when it wasn't supposed to. I heated up that copper or bronze strap and I put a little solder on the edge just giving it a little more resistance. I was using a 9v dc power supply to test it to make sure I haden't added to much which I had to remove some at one point. This may not be the scientific method you were hoping to figure out but I'm pretty sure it will do the Jobe just fine for you! Good luck! Silverfox
