Shade
Everything posted by Shade
  1. I'm trying to do the CPS Modification I can't seem to get the sensor to move down the metal bracket at all any tips>?
  2. I want to make this thing run as good as possible that is the goal here. This is not just about the truck running rich so any tips and things i should do now are welcomed new TPS, map sensor hose appears to be in good shape, not sure how to tell if the sensor itself is good.. new 02 sensor, newish coolant temp sensor I have a REM, its a manual.. when I'm shifting gears... it drops out of closed loop for a second and goes into open loop, once back down to idle it pops back into closed.. I'm almost positive it is not supposed to do this! (I would really like to know why this is happening) any tips are appreciated I really need this truck to be running as well as possible for not only my sanity but for the winter. one of the manifold bolts is broken off in the head and has been since I've owned the truck is it worth taking off the head to fix? ( might this be why I'm running rich?) I should probably go through all the vacuum lines there is a lot of gunked up oil in this engine bay on the vacuum harness as well as the valve cover ect seems like its coming out of everywhere that it could not sure where to start with that... (might some things be clogged up>?) grounds have been refreshed (and I've upgraded all of my battery cables) seems to run pretty darn good despite what I've mentioned
  3. gotta get me one of those for my longbox does not fit the greatest but its the best aftermarket I have seen for it
  4. well, if I was in utah ide forsure check this one out. does anyone happen to know what that camper shell came off of? Facebook Link
  5. Shade
    1JTHW6612GT194848
    I'm assuming they swapped in the one with actual needle gauges as it does not have idiot lights, and that's why the mileage is off
  6. Shade
    1JTHW6612GT194848
    Imgur link 2.4 / ax5 / D35 / Longbed Build date: n/a sticker completely faded Current Location: Santa fe NM seems to have traveled here from Oregon around 2018 Status: I've been driving it daily cause why not it seems to run fine to me Notes: just a stock longbox Comanche was totaled in 2017 and has a rebuilt title. mileage on cluster is almost 100% inaccurate though I'm not sure why someone would have changed clusters. Current owner: .
  7. I even checked local craigslist and facebook to see if it was listed locally I don't recall it even popping up
  8. shame it got removed I asked him if he had a buy it now price got no response and it seems that it has been removed from eBay now
