Hello,
I recently purchased a 1990 Comanche 4.0 5spd
The knock originates around the lower rear end of the engine block and bell housing, I can't tell for certain if its the engine block or bell housing. The knocking sound starts pretty much as soon at the engine starts, even on cold starts. Oil pressure when cold hovers a bit above 40 and as the engine warms up it lowers below 40 (around 30). The knocking seems to quite down a bit when warmed up but with that said it doesn't go away. The knock has a direct correlation to engine RPM, that seems to mellow at higher rpm. Please advise :)
I have disconnected each injector one at a time while engine is running, this did not make the sound go away.
Year: 1990
Engine: 4.0
Oil: 10w40 synthetic
Engine Oil filter: Wix
Transmission: AX-15 5 speed manual with internal slave cylinder
