MawnkyMJ
Everything posted by MawnkyMJ
91 Wonton Manche
MawnkyMJ replied to MawnkyMJ's topic in MJ Hardcore Tech: Epic Journeys to Greatness
Picked up a Barnes4wd XJ transfer case skid. Had to modify it to fit the MJ. There's a little bit of a gap, but not enough to stop it from doing its job. -
91 Wonton Manche
91 Wonton Manche
Thank you. It has been a two year project. -
91 Wonton Manche
So dummy me measured my DOM links wrong. They were too short from what I wanted to do. So I decided to just go solid aluminum links. -
91 Wonton Manche
So I bit the bullet and just decided to go full hydro. So that meant the front axle had to come back out. -
91 Wonton Manche
With the TNT Customs inner fenders I had to move my battery to the rear, so I picked up this old Coleman cooler. I made some cables out 2/0 welding cable and ran them to bus bars on the inner fender. -
91 Wonton Manche
91 Wonton Manche
91 Wonton Manche
91 Wonton Manche
Installed some TNT Customs inner fenders to help make room for the 40s. Drilling out all the spot welds of the stock inner fenders was fun. -
91 Wonton Manche
Got rid of the column shifter and installed a Winter's shifter. It will work well with the Niffty Shifter Jr. I also installed a couple PRP Daily Driver seats. -
91 Wonton Manche
1991 Jeep Comanche Pioneer 4.0 / AW4 / NP231 / 07 SD60 / Sterling 10.5 / SWB Build date: (its on the driverside door sticker, in the form of month and year) Current Location: Crystal City, MO Status: Back on the road and trails after a one ton axle swap. Notes: Lund Visor, Superduty axles, 40's, Steering wheel disconnect Current owner: Joshua Dautenhahn
91 Wonton Manche
It was time to finally mount the ORI's in their home for good. -
91 Wonton Manche
Finally bought my first house with my fiancé and was able to get the Comanche to the new house. -
91 Wonton Manche
91 Wonton Manche
Got the front axle set under the front and didn't touch the project again for another 6 months or so. -
91 Wonton Manche
Got the rear axle under the Jeep in the summer of 2020. My brother wanted to see what his wheels off his superduty would look like under it. -
91 Pioneer SWB Started out with just a stock MJ that the previous owner couldn't get to shift out of first. Figured out it was a just a broken ground wire.
Figured I would start a build thread. Even though the project is almost done. Build Specs: 91 Pioneer 4.0 AW4 4x4 07 SD60 4.10 gears 07 Sterling 10.5 4.10 gears Full hydro steering Front 14" ORI's PRP Daily Driver seats 40x13.50R17 MT Baja Bosses 17x9 Procomp wheels.
