Update: It was the fuse block. Crudy, loose and broken terminals. Thanks for all the help
Another "no parking lamp" post.... 89/4.0/5spd. HAVE: headlights, all 4 turn signals, both brake lights and backup lights. All hazards work. No parking lights front or rear. 10amp park fuse is good. There is power at the "B2" prong on the headlamp switch, with the pull switch PUSHED IN. As soon as you pull it halfway, or all the way out for headlights, the 12V goes away. NO power at the INSTR LAMPS FUSE... Not sure if that could affect the circuit other than losing dimming capability. I tried 3 different headlamp switches.... All have the same outcome, so I don't think it is the headlamp switch. It did have a leaking clutch master cylinder, and the fuse block is a bit finicky. I've had it apart a couple times and everything looks like it should...What am I missing/overlooking/not understanding??
