Bob89manche
Everything posted by Bob89manche
  1. Motherf***** . It’s 100% the lamp connector. No clue as to when it was plugged into the coil or by whom. I just took it as if it were supposed to be there. JC I feel like an idiot
  2. This solid red wire is coming from suspect fuse link, running into the connector, and from the other side running straight into the ign coil. The plug in the middle of the pos and neg terminals that rest into the clips on the top side of the ICM.
  3. Tested coil. It passes. After c102 is dc’d we still have continuity. Tore RH headlamp out, there is no relay back there. Seems Like all wires running behind the grill are all solid. No problems
  4. Solid red wire from this connector goes into IGN coil. Red/white goes behind RH headlight through the loom. With this connector DC’d, no problem. With IGN coil unplugged, no problem. On the ICM, multi wire connector unplugged, no problem, singlular yellow wire connector unplugged, problem persists. Is it possible the short from yellow to red exista in the coil? I replaced this early on in the summer
  5. I think my under hood light was ripped out at some point. Would be a blessing if it was still there. It seemed to have originated at the green fuse link that has been problematic. It is possible that this is incorrect as I had a helper with me at the time.
  6. Solid red wire on the right side of this connector has continuity with fuse link bundle disconnected
  7. Removed all fuse links from starter relay. Tested continuity between d2-4 and problem fuse link. With fuses removed, no change(car not running). Fog lights remain on when fuse is pulled(car running)
  8. This is the only fuse link that is reading resistance. It was 2 green fuse links in one ring connector but I split them. This one splits to 3 solid red wires. Also, all other posts on the starter relay read resistance as well. It’s 18degrees our today. Fml
  9. This is actually how I started this. With less direction and record keeping, obviously. Will get back with results. Thanks again everyone
  10. I didn’t have the batter connected when I messed with the ign switch, but even if it’s completely unplugged the ign system still is energized when battery is connected
  11. I went back through the ignition switch. And cylinder. Both have been replaced within the month. Have the lock cylinder all the way off and the switch all the way in the same direction. Popped the lever hook in the switch, made sure the lever arm is taught and tightened down the bolts and hibeam assembly on top. All tight and lined up. It just screams electrical to me. As soon as the pos terminal is connected I’ve got power to all relays and ignition. The only thing the lock cylinder changes is the radio and cigarette lighter power supply at this point
  12. I’ve been wondering if my lock cylinder connection to the arm that interacts with the ign switch might be faulty. It just seems like more of an electro issue than mechanical at this point
  13. Did the wiggle with ign switch unplugged and also plugged in. No change. Infinite resistance. Followed yellow down to Passenger side headlight. Might need to check the long run in front of radiator
  14. I’ve already replaced the ign switch
  15. Interesting. Reading infinite resistance constantly From that connection. No change when ignition switch is removed
  16. Help me out with the terminology “engine harness side”. I’m taking it as the side of c103 that leads to the majority of the engine wiring, passing behind the radiator and on to the other side of the engine bay as opposed to the side that leads to the diagnostic ports. Am I correct in this interpretation?
  17. Right. Previously I have disconnected fuse links from the starter relay to try and isolate the problem. I found that dc’ing the dual green/orange link to individual red wires and green link split to 2 red wires stops the flow of power. Too dark to mess with tonight, but will start looking at/replacing fuse link G tomorrow
  18. Dude, nice catch! Now with the real c103 DC’d I’ve got infinite resistance showing on the DMM.
  19. I have ones that are similar in shape and configuration, but not with each of the 6 ports with a wire. (Some with 3, some with 4)
  20. Changed the oil, drive to a buddies, came home. No problem. Next morning parked at work and it wouldn’t shut off
  21. Thanks. Makes sense as I’m 2WD and no cruise control. Maybe I can just set it on fire and score an insurance payout 😫
  22. I followed these instructions. I also have gone through the wiring harness from relay bank/diagnostic bank up to the MAP sensor checking for any shorts. Going through up to C101 tomorrow. As of now, no change. Found some less than satisfactory connections but all In all, it’s not bad. Not been hacked into by POs at all. Attaching photo of non related connections I found that look like they could go together but seem to be situated too far away from each other.
  23. Will do this weekend. Thanks Ohm. Will update soon
