Smoketrail
Everything posted by Smoketrail
  1. All tests were done with key on.
  2. Removed both flashers and tested voltage. Hazard socket went from 0-11 volts when hazards were turned on while the turn signal socket went only from 0-.15 volts when turning on the signals. What next?
  3. Tested everything in the ACC position. AC blower worked, radio worked, wipers worked, and Horn worked after a couple presses. Turn signals still do not work.
  4. Thanks, Thanks, I will check those things. It is a 1989 Jeep Comanche with 4.0 inline 6 cylinder engine, 5 speed manual transmission and air conditioning, retrofitted to 134a refrigerant.
  5. Old Fuse was not blown new fuse is not blown, switched the flashers but did not help. Anything else?
  6. I have same problem. Hazard lights, brake lights, reverse lights, work fine but neither the right nor the left turn signal lights up on the outside, and also no indicator on the dash. I replaced the fuse, but no effect.
