Bryson
Bryson's Achievements
  1. Let me know how this works out. I also need that same part replaced on mine. I did the header but that old down pipe is rusted to hell.
  2. I have an 86 MJ with the 2.5 tbi engine. I am currently switching to a fuel cell with external pump. I have everything ready to run new 3/8 steel line from the setup to the tbi; however, i am having a hard time finding the right connectors for the inlet and return line to make the switch. Does anyone know the right part to swap them hard line connections out. Mainly looking for the threaded part for the tbi. thank you in advance
  3. Yes iv changed the filter. I also hooked up an air line to the oil pressure sending unit and still get nothing. I could hear the air come back out the top breather when we tried it
  4. Hi Everyone, I'm looking for some suggestions on what to try next. I currently do not have any oil pressure. I have a origional 2.6 4 cylinder 86 commence. The engine was fully rebuilt about 5 years or so ago. I got manual gauge and tested the pressure and still got 0. I also took the gauge off and just had the hose hooked up and it barely dribbled out. After that i dropped the pan and changed the oil pump and did not find any spun bearings. Engine has no nocking when running. Any help on what to check next would be appreciated. Thank you,
  5. Ah! thank you. now to figure out what the other random wire goes to lol
  6. let me know if you can see these 2. Its not the tile pressure one because that is already connected.
  7. I everyone I just bought a new to me 86 Comanche long bed about a month ago. It had been sitting in a barn for about 5 years or so not running. I was able to get the ole 2.5 up and running but am having hard time finding what sensor went in the threaded hole on the side of the engine block close to the spark plugs. I'm pretty sure it is a temp sensor that goes to the computer but the only sensor i could find was the coolant sensor and its to large to thread into that hole by just a smidge. The wire is there for the missing sensor so i just want to hook it up if that is even what is missing there. Thank you in advance for you help. .ngine1 .ngine2 .ngine3
