myros
    Arlington VA
myros's Achievements
  1. I think I found it, I think the hole is for the oxygen sensor port, and I can find an oxygen port plug online or local auto store.
  2. I received the new pipe and so far it looks exactly like the one i removed from the car. I have a question with regards to the hole near the top, what is that hole for? and what can I use to plug it? The old one seems to have the hole plugged.
  3. Will do, thanks for the tip
  4. I'm redoing that part too and everything else downstream so I should be able to put those together. I was concerned about the bends at the front. Thanks!
  5. I think so, I have ordered the part, if it is a total miss i will return it, if is minor adjustments I will try to install it. Will report back once I get the part. Thanks
  6. Hello everyone, first time posting here. I have a 1986 JEEP COMANCHE 2.5L 150cid L4 and I am replacing the exhaust front pipe. I have found in several places the Walker 44320 pipe but it is marked for 87 to 90 jeep comanches: https://www.amazon.com/Walker-44320-Exhaust-Pipe/dp/B00199L2NA/ref=sr_1_7?dchild=1&keywords=walker+44320&qid=1591445844&s=automotive&sr=1-7 Does anyone know if it would work with an 86 4 cylinder as well? Thanks
