EanS13
294 profile views
EanS13's Achievements
  1. Clutch kit would be the same from the 94-96 cherokee as well?
  2. I don't have the master and slave combo actually since I'm not sure from which year and model i can get them from. However my trans is of the later model. Can i reuse the BA10 transmission mount or is there a different one for the AX15? What about the drive shaft? Since i have the long bed itll be harder to find that longer drive shaft with the 23 spline can i just replace the U joint at the trans/drive shaft or is there a length difference?
  3. Hi everyone. I currently have an 87 Jeep MJ 4.0 with the BA10 transmission 2wd. I am currently in the process of changing out my BA10 for an AX15 and already have in my possession and AX15 transmission with the external slave cylinder and I plan on keeping it a 2wd. But i was wondering what other parts will i need and what else needs to be changed over and what years and models from other jeeps I may be able to find them on. I know the crossmember will need to be changed and since they are so hard to find I was wondering if there are any conversion kits that may exist to help out. Thank you
