mjcatz
Everything posted by mjcatz
  1. Yeah, calipers aren't too straightforward, but because it's exactly .750, you just read off the zero on the right. If it aligned with another number, that would just indicate a fraction, like .755. And you're implying that the mount is hit-or-miss, and it may fit perfectly, but could also need modification?
  2. The input shaft looks to be 0.750 exactly, so the pilot bearing I had listed should be the correct one.
  3. I recently acquired an AX-15 transmission and want to swap out my current BA-10/5 for it. I don't have any donor parts from the original vehicle, so I need to make sure I purchase all the correct components. If I purchase this adapter, I should be able to use the existing x-member and mount, correct? http://www.advanceadapters.com/products/716007--nv3550--ax15-crossmember-mount-kit-for-jeep-yj-wranglers/ And I know the 4wd shift linkage is different, so I'll need something like this? http://www.advanceadapters.com/products/715545--transfer-case-shifter-bracket-jeep-np231/ The X-15 was pulled from a '92 XJ, so I believe I should be ok with the existing hydraulic throwout bearing (I believe '93 and later need the external slave cylinder). I'm placing it in a 1989 MJ, and from what I've read, the later BA-10/5 outputs could be either 21 or 23 spline, so I'm not sure if I need a new input gear for the t-case. Also, is this the correct pilot bearing I would need? http://www.advanceadapters.com/products/716164--pilot-bearing-750-id-x-1818-od/
  4. I've run a Flowmaster 40 for a while on my MJ. I would agree, sounds great at idle, but the tone gets really muddy at higher revs.
